I want to attach XDATA to a .dwg file which contains over 1000 block objects approximately.
I'm using AutoCAD 2020.
Are you trying to attach the data to the blocks or the drawing?
CADnoob
Hi @ballalyash
Plain vanilla AutoCAD can't deal with XDATA because it doesn't read or understand it. You'll need to use either AutoCAD Map3D or AutoCAD Civl3D, both have the capability to read XDATA.
You should download a trial version of the >>Map3D toolset.<< If you have questions, post them in the AutoCAD Map3D Forum, not this one.
Chicagolooper
@ballalyash wrote:
Sorry, my bad.
My requirement is for individual objects, but xdata should get attached to all the objects present in a Drawing.
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-F0299B36-232F-446E-9F81-98F300B36991
https://help.autodesk.com/view/ACAD_E/2024/ENU/?guid=GUID-E726F9EF-D82D-4A10-97FC-BEE98E540702
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-FA8BBFB8-5C3E-4742-A3A2-CBCDB168FB08
https://www.keanw.com/2007/04/adding_xdata_to.html
HTH
Command XDTOOLS_ADD from XDTOOLS.
