how to align the height of 7 objects
Message 1 of 9
Hi all,
I wanted to know how I can align the height of 6 objects to a base together, so at the end they are sitting at the same point, and at the same height.
I'm new to Autocad, and I'm pretty sure its easy to do this.
Thanks for your time.
Replies (8)
Message 2 of 9
imadHabash
Hi and Welcome to AutoCAD Forum,
it depends on your objects , is it a Texts,Blocks,dimension lines,...etc it can be done for some and others not . SO the question here what kind of objects you want to align ?
Imad Habash
Message 3 of 9
the 6 obejcts, as well as my base, are all 3d solids, and Im trying to find a common height level across all of them
Message 4 of 9
imadHabash
can you attache an screen shot image for your objects please ?
Imad Habash
Message 5 of 9
Hey man, I just saw your message
Heres what I'm talking about:
I want the gold object to sit on top of the gray base, with no space in between them, and by gold object, I mean all of the gold objects
Message 6 of 9
imadHabash
i suggest to use 3DALIGN command  . >> Click <<
Imad Habash
Message 7 of 9
s.borello
will 3d align command work for you?
Message 8 of 9
I've attached my Move_in_axis.lsp, It's a bit clunky and redundant but has served me well for a couple of decades. Drag and drop the lisp into the drawing (or autoload if you want). Let's say you wanted to align the bottom of one solid with the bottom of another.  Type in the command (from below) and pick the point you want to move (bottom corner for instance) then select the point it's supposed to align with.  Be sure you know where your USC will take you!
So, you have 7 solids and want them to align on the same Z-plane.  Move the UCS to a point on the base solid that you want others to align with.  that point should be  for instance 12,4,0 (zero being important here). Now, M2Z, select object, select point. Enter, repeat.
There are commands in AutoCAD to do this that are easier if you're used to them. But I've found that "MNZ click click" is pretty easy too. At any rate,  it's free, it works.  Who can argue!
Have fun!
Don
The commands are
MNX - move in X-Axis
MNY- move in y-Axis
MNZ- move in z-Axis
MNXY- move in X-Y-Axis (filters out any z component
M2Z- move to Z-axis
CNX- copy in X-Axis
CNY- copy in y-Axis
CNZ- copy in z-Axis
Message 9 of 9
hi, I will look into it. Thanks!
