AutoCAD Forum
How to accurately project a 2d shape into 3d model.
8 REPLIES 8
Message 1 of 9
marcos9593
579 Views, 8 Replies
I am having trouble using PROJECTGEOMETRY on a 2d shape against a 3d solid accurately. I have a piece of Velcro that I want to make a curved cavity for. The purpose is to join a dimensioned Velcro piece onto a plastic cover, like a jig/fixture. My results are coming out distorted, the cavity is smaller and doesn’t allow the Velcro to fit inside. How???
8 REPLIES 8
Message 2 of 9
Valentin-WSP
in reply to: marcos9593
@marcos9593 ,
Provide your drawing with the 3D and 2D geometry.
Consider this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 3 of 9
marcos9593
in reply to: Valentin-WSP
Hello Valentin,
I attached a short clip of the PROJECTGEOMETRY, this is what i want however, i need to figure out how to make the projection to scale; 3D printed model with the projection command but the cavity is stretched rather than a natural bend into the 3D model. Could there be a different way to bend the 2d profile.
Thanks for the help!
Kind regards,
Message 4 of 9
schulz8NPAP
Perhaps something like this??
Regards
Jochen
Message 5 of 9
Valentin-WSP
@marcos9593 ,
@marcos9593 wrote:
I am having trouble using PROJECTGEOMETRY on a 2d shape against a 3d solid accurately. ...
how to make the projection to scale. ...
PROJECTGEOMETRY is limited on projecting to scale. I thought about "Parametric", but this is a technology that is used for designing with constraints, which are associations and restrictions applied to 2D geometry. (Link)
I believe another Autodesk software could be more suitable - something like Inventor (See Bend Command) or Revit.
Emilio Valentin
Message 6 of 9
leeminardi
Would it be more accurate to say you want to "wrap" and not "project" the 2D geometry onto a cylinder?  If so then if the length of the 2D shape is L and the radius of the cylinder is R then S = L and the angle subtended is S/R radians.
lee.minardi
Message 7 of 9
marcos9593
in reply to: schulz8NPAP
Hello!
How did you do that??
Message 8 of 9
marcos9593
in reply to: leeminardi
Good morning,
yes, in this case it seems more of a wrapping Of the 2d shape but the method remains unknown. Any ideas?
thanks for all the help!
kind regards,
Message 9 of 9
schulz8NPAP
Hello and thank you for your interest.
Attached ist the continent of Africa (3DSolid onto a bulb-formed earth 😉 )
You can reach me by
www.black-cad.de
Regards from Germany
Yours Jochen
Forma Design Contest
AutoCAD Beta
