![](/skins/images/42360393413CFB59142C5AC63B8F7E79/responsive_peak/images/icon_anonymous_message.png)
- Mute
- Permalink
- Report
I have blocks with attributes (lighting instruments). There is a front and a back to the block with attributes on both. When I created the block I made the attributes read correctly with the front of the block pointing up. When I place the blocks on drawings they may be placed pointing up but also pointing at an angle or pointing down. Unfortunately the attributes, when the block is rotated, will always rotate with the block but not adjust to the correct angle for reading. For example when the block is rotated from pointing to pointing down, the attributes are upside down. Is there a way to have the attributes rotate correctly when the block is rotated? If not, is there a way to correct the rotation of the attributes. When I use Enhanced Attribute Editor, I can correct the attributes one attribute and one block at a time but the attributes are not where they were placed when the block was pointing up. The relationship of attribute location to block is changed. Anyone have any ideas?
