Which software best suitable for Landscaping design
Currently I’m studding for landscaping design. I’m now at a point I have to make a decision to choose witch software I wat to use to design gardens. Since is quite a learning curve to fully understand a software program, I want to make the right decision what software to choose.
Required possibility’s
- 2D garden design
- 3D garden design
- Technical drawing (deck, pond, lighting, sprinkler system …)
I’m think it’s a good idea to achieve a certificate of the program(s) needed.
What is the best program to use for my needs?
And should it be Autodesk or Vectorworks, SketchUp, or something else?
pendean
Community Legend
Community Legend
Where you are studying, what do they recommend you use for software?
Otherwise if you want to go it alone there are many choices:
https://www.google.com/search?q=landscape+design+cad+software
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Dean makes a good point that your instructor/courseware might be able to make good software suggestions.
If you are looking towards smaller residential projects, you might find AutoCAD LT sufficient for 2D work. However, you indicate that you are looking towards 3D as well. Is this merely for presentations or are you also trying to do cut-and-fill calculations? If the latter then you might consider full AutoCAD or even something like AutoCAD Civil 3D or Revit.
I have not used Vectorworks in quite sometime so I can't offer any suggestions there. Sketchup might be good for presentation work but in my opinion will not yield the same amount of options for construction calculations and documentation that AutoCAD might offer.
There are couple of add-ins available in the Autodesk App Store that might be useful if you want to download a Trial of AutoCAD.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
scottU373U
Community Visitor
Community Visitor
I've had the opportunity to work with a variety of landscape design software over the years, and I find that SketchUp is a great option, especially for those who value flexibility and ease of use. It's particularly effective for creating detailed 3D models that can really help clients visualize the final outcome of a project. Here’s a link to more info on how SketchUp can be used for landscape architecture: SketchUp for Landscape Architecture.
In addition to software, it's important to consider the experience and expertise of the design team behind the tools. At Pitt Landscape & Construction, we combine cutting-edge software like SketchUp with our extensive knowledge of landscape architecture to offer full-service design solutions that are both functional and beautiful. If you’re interested in learning more about our custom landscape design services, feel free to check out our website: Pitt Landscape & Construction Design Services.
I hope this helps, and I’d be happy to discuss more about software choices or share experiences with specific tools if anyone’s interested!
Best,
Scott Jolley
