How do I put a point in the center of my line?
Let's say I wanted to put a point in the center of a line a just created or, the end of a line etc.
How do I go about doing that?
imadHabash
HI,
as much as i understand your issue ... from PTYPE command select your needed style . then type POINT command and with Midpoint osnap mode ( Osnap command ) you can make it .
Imad Habash
Kent1Cooper
For the point in the center, you can use DIVIDE:
Command: DIVIDE
Select object to divide: {pick the Line, or Arc, or other finite-length object with linearity}
Enter the number of segments or [Block]: 2
But ordinary DIVIDE won't put them at the ends.  You can do the midpoint and both ends all at once with the DIV+ command defined in DivideMeasurePlus.lsp, available >here<, using the option to put them at the ends [Divide won't do that].  If you want the endpoints only, not the midpoint at the same time, use the same command and ask it to put them at the ends, and for 1 segment [which regular Divide won't allow].
Kent Cooper, AIA
rbh1
Sorry I did not see the Comment from ( @Kent1Cooper )  a little overzealous  🙂
You can also use the divide command. shown below
Command: DIV
DIVIDE
Command: PDMODE
Enter new value for PDMODE <0>: 3
Regenerating model.
