How do I fix the font size in my drawing?
I'm trying to get all the dimensions, tolerances and title block all around the same size. I've been changing several settings and playing with standard and annotative styles. I can't seem to make everything the same size.
Replies (10)
john.vellek
Hi @@Anonymous,
I suggest removing the overrides and then making your DIMSTYLE Annotative. This way the text will scale automatically based on the scale of your viewport.
Let me know if you need help with the process.
John Vellek
yeah ill need help with that
edit: I deleted the overrides and made sure it was on annotative. Nothing changed.
How do I get to the settings you posted? I typed dimstyle and it didn't look like that.
john.vellek
Hi @Anonymous
Did you then reapply the style or update the objects?  I included my version of your file to see what I have changed.
John Vellek
I clicked the update button after I did everything in your instructions. Nothing changed. I attached my current file.
john.vellek
Hi @Anonymous,
Try this:
Open your Text Styles and create a new style. It should have a height of 0 and be set to annotative.
Next, open your ISO-25 dimension style and assign your new text style to the text style for your dimensions. Assign a height of 1.
On the Fit tab select Annotative
This should fix most of your text. You will also have to go through a similar process to fix your Mleader style.
John Vellek
how did you create the new style? this is what I'm trying and it doesn't seem to work. The new style doesn't show up for me to select it.style.PNG
john.vellek
Hi @Anonymous,
I am sorry you are stuck on this process. I have made a Screencast video using your file. I hope that you can follow the steps. If not, let me know and I can try something else to explain the process.
John Vellek
I can't seem to figure out how you make the A datum on the side view the right size. Also the title block looks sloppy. How do I fix that?
heres my current file
john.vellek
Hi @Anonymous,
First, I created a new text style for your title block. The info you are typing is always going to be 1:1 so there really isn't much point in using an annotative style. You will notice that I also give all of my styles a unique name and do not use the built-in ones such as Standard.  I also don't like to assign the height in the style, rather I apply it to the text itself.
Next, I went into your dimstyle and set the text height to 2. Then I used the dimsension Update and selected all of your dimensions to apply the change. I did the same thing with your mleader style (text ht=2 and arrow size 2.5)
It looks like you are trying to apply individual text height overrides which you shouldn't do. Let the style determine heights for you.
John Vellek
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
