How do I draw these angles in from this survey plan?
hgh8791
Message 1 of 14
hgh8791
Community Visitor
Community Visitor
02_48_35 2025-08-28-KAP57771.pdf - Foxit PDF Editor.jpg03_02_13 2025-08-28-KAP57771.pdf - Foxit PDF Editor.jpg
Replies (13)
Message 2 of 14
imadHabash
Hi and welcome to AutoCAD Forum,
Enter the point using distance < bearing (@distance<bearing)
(Use d for degrees,  '  for minutes, " for seconds).
Command:  LINE
Specify first point:  select any point Or any known one
Specify next point or [Undo]:  @63.171<125d39'50"
Keep going for all other distances till you reach to the final shape depending on given numbers.
Imad Habash
Message 3 of 14
hgh8791
Community Visitor
Community Visitor
How do i handle those arc lengths?
Does the "a=63.171" represent the length of the line and then "140d30'26" represents the angle of the line as an arc?
It just not coming out how it looks on the drawing when i try to map it, so i'm confused.
Thank you!
Message 4 of 14
imadHabash
a=51.268     /     r=72.500
draw a Line with 51.268 total dimension then draw the Arc from both line ends with ( Start,End,Radius ) option.
Click on below image...
Imad Habash
Message 5 of 14
richard_387
The "a=63.171" represents the arc (curved) length of the line, and the "140° 30' 26"" represents the whole circle bearing to the centre of the circle, whose radius is given by "r=243.840"
You will note that there is a dotted line at right angles to the arc at each end, and these tell you the bearings at each end. You will also note that these bearings are not exactly at 90° to the bearings of the preceding straights, so the whole survey is not exactly precise, but suffices for a survey drawing.
To use these angles directly, you should set your angle direction to clockwise and have the zero angle at North. The units are in metres.
Message 6 of 14
imadHabash
Arcs can be done as my previous attached image massage #4
Lines ... as i mention it for you in my first massage #2
Imad Habash
Message 7 of 14
autoid374ceb4990
If you do not mind my asking, where did your survey plan come from (state/country)?
Message 8 of 14
R_Tweed
Here is a method to draw arc that will fit within dimensional tolerances.
1. Draw circle with radius shown.
2. Draw reference angles used to locate start and end of arc.   (dashed line with open circle)
3. Draw arc using center, start and end. Using the center of circle drawn and angle points.  The arc length will be close but not accurate due to the angle values used.
4. Use lengthen to make arc the total length as given.
5. Rotate your arc using center and mid point to align the mid point with a bisecting line of the tow angles drawn.  This will center the arc and overlap the two angle slightly.
6. Rotate the angles to match arc end points. ( check angle against current units) it will display proper angle as the adjustment is within accuracy limits.
I've attached a dwg of example.
Message 9 of 14
CGBenner
@hgh8791
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Message 10 of 14
hgh8791
Community Visitor
Community Visitor
Hello! British Columbia, Canada!
Message 11 of 14
hgh8791
Community Visitor
Community Visitor
I've been trying to do this (setting zero angle to north) and have tried looking this up since it seems to have been asked a million times on the forum here but I just can't figure out what I'm doing wrong. I'm on autodesk civil 3d 2020, planning and analysis. ddunits -> direction... -> base angle says "East = 0d0', North = 270d0', West = 180d0', South = 90d0', Other = Pick/Type". What do I change about this to make zero angle be north? Every time i try to change something I get back to these same options in Base Angle. ie. the Base Angle options stay the same.
Message 12 of 14
Kent1Cooper
@hgh8791 wrote:
...(setting zero angle to north) .... What do I change about this to make zero angle be north? .....
Command: ANGBASE
Enter new value for ANGBASE <0>: 90
If you want angle progression to be clockwise instead of CCW:
Command: ANGDIR
Enter new value for ANGDIR <0>: 1
Kent Cooper, AIA
Message 13 of 14
AllenJessup
If you're using Civil 3D. There's a whole ribbon that gives you access to commands for drawing Lines by Bearing and Arcs. Use the Civil 3D Workspace.
There are also Transparent Commands that will work too.
Allen Jessup
CAD Manager - Designer
Message 14 of 14
richard_387
You are nearly there! With the command ddunits, you set clockwise by clicking in the box in the Angle section. Then when you go on to Direction, you want North to be your Base Angle, so you choose that. Do not worry about the angles shown, they are something else.
If you want to use the System Variables, you have to think slightly sideways! For ANGBASE, the angle you enter is the value you want for the bearing to East i.e. 90. For ANGDIR, 0 is anticlockwise, and 1 is clockwise.
