Batting lines do not plot properly - AutoCAD
2024_11036
2024_11036
So I was working on this plan of a house and I was drawing the insulation layers - they look normal when I'm in the model but they look really freaky when seeing them in the layouts or when plotting them into PDF. How do I fix this issue?
@2024_11036 Your post title was modified to add the product name and to increase findability - CGBenner
imadHabash
I suggest to:
  • set   PSLTSCALE = 1   in your viewport layout. Don't forget to Type REGEN OR REGENALL to update the linetype scales for objects in your viewports.
  • set the right and correct scale for your VP.
Attach here your CAD dwg sample for testing please?
Imad Habash
2024_11036
I tried doing that but to no avail. I changed the dimensions through SCALE and now the batting lines appear as normal ones unless I zoom in the viewport, then the problem happens again.
Here is the file in the attachment.
pendean
Community Legend
Community Legend
@2024_11036 Set your PSLTSCALE to 0 (that's a zero) in each of your layouts, then run REGENALL command.
2024_11036
It's finally working! Thank you very much!
