How do I draw a dashed polyline like the one in the image? I can't figure out how to change the scaling (V->H).
cipu_marinel_d3h
cipu_marinel_d3h
I have to draw a polyline like the one in the image (there's another line behind) and I can't really figure out how I should do it since it has a vertical dash pattern instead of a horizontal one (it's my first time using Auto CAD and I'm not yet used to the settings).
here's what it should look like:
and here's my drawing:
Thanks!
paullimapa
What's your current ltscale?
Since the dash needs to be further apart, try increasing the ltscale
Perhaps share your dwg?
Paul Li
IT Specialist
@The Office
cipu_marinel_d3h
My current ltscale is 1. Increasing the ltscale wouldn't be the best choice since there are 2 other dotted lines, or maybe there is a way to modify it just for the polyline? Thank you for the help!
I've also attached the dwg file.
paullimapa
A couple of issues. You've set the current Linetype to HIDDEN instead of BYLAYER
And since this is a metric drawing you should be loading the Linetypes from file acadiso.lin & not acad.lin
These are the steps I took to modify your drawing:
Command: CELTYPE
BYLAYER
Select the PLINE in question and change the Linetype from Continuous to Bylayer
Command: LTYPE
Select Load button
Click File button
From AutoCAD's support folder select acadiso.lin
Select Hidden2 and click OK to dismiss the window
On Layer Properties Manager select layer Dot2 and change the Linetype from HIDDENX2 to HIDDEN2
Now you'll see the Linetype develop on the PLINE
Paul Li
IT Specialist
@The Office
cipu_marinel_d3h
Thank you for your help, and sorry for replying late. It works just fine now (I've tried that on different projects as well)! 🙂
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
