How do I disable annotative text
rudygVGPE7
Observer Observer
rudygVGPE7
Observer
Observer
I never use annotative scales or text and it's tedious to turn it off every time I start a new drawing. Is there a way to permanently disable it?
Kent1Cooper
Change it in all your drawing template files.
Kent Cooper, AIA
Michiel.Valcke
Change the text and dimension styles in your template tot non-annotative
jayhar
Can you please upload Screenshot
Enter new value for ANNOMONITOR <0>
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Valentin_CAD
@rudygVGPE7 ,
There are advantages in using Annotative Scales and Annotative Styles.
Maybe seeing how to use it could bring some benefit - check out this video:
However, to make it less "tedious" try these suggestions:
Yes, but that will require you to update all annotation objects and styles in your template:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
