& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
How can I disable this Sky/Horizon in model view? I don't need to see a horizon when I rotate some mechanical part.
Is it possible to set an omni-directional light source?
BACKGROUND command may help if you select None type .
regards,
Imad Habash
There are two ways to do this:
1. Use the Display tab in your OPTIONS to change the Colors (button) while in 3D Projection. If you do this I'd recommend setting a new profile current so you can always go back if you want.
2. Use the VIEW command to create a view with a solid color BACKGROUND - set that view current. Like #1 above you want to create a separate view with the DEFAULT background so you can switch back.
#1 is good for your COMPUTER (All drawings), #2 is good for the current DRAWING (But if you do it in your template it will be good across all drawings you use that template for.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Good one Imad! I forgot that was a separate command.
Warren Geissler
Thanks a lot Imad!
That did it. Your solution was simple & direct, so it is the correct answer to my "problem".
Cheers!
Hi Warren,
Thanks for your kind assistance.
Using the BACKGROUND command was the simplest and most direct solution for me.
Cheers!
Hi Bhatia,
Thanks for your efforts... but the single command BACKGROUND did the trick.
Cheers!
I'm using Mac version of AutoCAD 2022 and there does not appear to be a "Background" command at all. 😕
Thanks, I was wondering how to get rid of that annoying white-to-black background (some call the horizon). It is now all black.
Hi
Try this (I got it from Google):
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
