How can I disable this Sky/Horizon in model view?
How can I disable this Sky/Horizon in model view? I don't need to see a horizon when I rotate some mechanical part.
Is it possible to set an omni-directional light source?
Replies (10)
imadHabash
BACKGROUND command may help if you select None type .
regards,
Imad Habash
WarrenGeissler
There are two ways to do this:
1. Use the Display tab in your OPTIONS to change the Colors (button) while in 3D Projection. If you do this I'd recommend setting a new profile current so you can always go back if you want.
2. Use the VIEW command to create a view with a solid color BACKGROUND - set that view current. Like #1 above you want to create a separate view with the DEFAULT background so you can switch back.
#1 is good for your COMPUTER (All drawings), #2 is good for the current DRAWING (But if you do it in your template it will be good across all drawings you use that template for.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
WarrenGeissler
Good one Imad! I forgot that was a separate command.
Warren Geissler
Click Render tab System panel Autodesk Rendering .
Click the Environments tab, go to the Sky panel. If the controls are not active, you need to turn on the sun light first.
If you want to magnify the effect of the sky light, change the value in the Intensity Factor field.
Move the Haze slider to adjust amount of haze in the air. The range is from 0 (a completely clear day) to 15 (extremely overcast, or sandstorm in Sahara).
Move the Horizon Height slider to tune the position of the horizon. This affects not only the visual representation of the horizon (ground plane) but also the point where the sun 'sets'.
Move the Blur slider to adjust the amount of blurring between ground plane and sky.
Click the Color picker in the Night Color field, and set the desired value. This is the minimum color of the sky - the sky will never become darker than this value.
Click the Color picker in the Ground Color field, and set the desired value. This will be the color of the virtual ground plane.
Thanks a lot Imad!
That did it. Your solution was simple & direct, so it is the correct answer to my "problem".
Cheers!
Hi Warren,
Thanks for your kind assistance.
Using the BACKGROUND command was the simplest and most direct solution for me.
Cheers!
 Hi Bhatia,
Thanks for your efforts... but the single command BACKGROUND did the trick.
Cheers!
tsosnoskiNG93X
I'm using Mac version of AutoCAD 2022 and there does not appear to be a "Background" command at all.  😕
ktnalive
Thanks, I was wondering how to get rid of that annoying white-to-black background (some call the horizon). It is now all black.
ktnalive
Hi
Try this (I got it from Google):
To change the background color in AutoCAD for Mac, you can do the following:
  1. Type OPTIONS on the command line
  2. Click the Look & Feel tab in Application Preferences
  3. Click the Modelspace menu and select the desired color
  4. Click OK
