How can I delete the inner lines of the mesh?
danismanm
danismanm
Hi! I had roads as mesh in my dwg file. I applied the FLATTEN command. Now I have all the lines one by one. But I need to delete the lines inside the roads, except for its outer lines. The SELECTSIMILAR command does not work because the inside lines and outside lines are in the same layer. How can I have only the outer lines of the roads?
pendean
Community Legend
Community Legend
manually I suspect based on your descriptions alone: can you share your actual DWG file?
danismanm
thanks. I edited and added screenshot and dwg.
pendean
Community Legend
Community Legend
Thanks for the file: other than OVERKILL command getting rid of ~180000 duplicates, I see no other easy automated method to remove the other excess lines from your DWG file. Sorry.
danismanm
Is there any step I can take before FLATTEN the mesh?
pendean
Community Legend
Community Legend
Can you share your original DWG (mesh?) before flattening and exploding etc.?
danismanm
Here is the original mesh. Thanks a lot for your help.
