How can I change multiple mtexts font at once?
 Hi I need to change all the texts font to "txt" from "Arial" because of the problem of the lasercut. Is there any way that I can select all the mtexts and change their font to "txt" instead of selecting them one by one and change them. Ty very much for your helps.
user181
You can use the QSELECT command and fill in as seen in pic below. Then click ok and it will select all text on that style and you can then change the style on the properties palette.
