08:52 AM
- Mute
- Permalink
- Report
I am looking at different software to fit our fabrication needs. We build large signs with mainly aluminum angle , channel and sheet goods. We use LED Illumination. All signs are usually mounted to steel poles set in concrete footings via saddle/pocket mounts. I like the isometric views because it tells the whole story. Also I would like the software to generate a cut list for each job.
I have attached of a Sample Job (I want to up my game and you can see why)
Any help would be greatly appreciated.
