houdini pictures
houdini pictures
Message 1 of 18
houdini pictures
im having an issue with pictures. ive attached pictures into a drawing but everytime i save and exit once the drawing is reopened the pictures are gone. what am i missing here?
Replies (17)
Message 2 of 18
pendean
Community Legend
Community Legend
>>>...what am i missing here...<<<
How did your "attach the pictures" exactly? Name the command, walk us through the process.
Where are the "pictures" located in relationship to the DWG file and folder?
Message 3 of 18
TheCADnoob
are they presnet in the EXTERNALREFRENCE dialog?
CADnoob
Message 4 of 18
insert>>> attach>>> select ref file. they're in the same file folder
Message 5 of 18
yes and the ones that were previously loaded that it messed up have the yellow caution symbol by them and say unrefed
Message 6 of 18
when i click on the words where the picture was it says the file is unsupported
Message 7 of 18
TheCADnoob
what is the file type and what is the file size?
CADnoob
Message 8 of 18
.jpeg/39.9kb
Message 9 of 18
LyleHardin
"Unreffed" usually means they've been erased from the drawing without being detached.
I suppose they are showing up in the drawing once you've attached them.
You open the drawing again and they are gone or just boxes with text?
How about doing an eTransmit and attaching the zip file so we can take a look?
Message 10 of 18
TheCADnoob
I suspect it might be your path.
Is this the unsupported image file dialog?
If so try changing your path in your external refrence dialog box
EXTERNALREFRENCE
I would make the path relative first, and if you get no success i would try absolute.
after that point it to the file again. Its lower down in the external reference dialog box.
CADnoob
Message 11 of 18
im in 13 so it looks a tad different. if i right click on the ref it gives me  path > remove pathor make relative. should i unattach all the refs and start from the beginning. none of them are recognised anyway
Message 12 of 18
pendean
Community Legend
Community Legend
Show us your expanded XREF palette in a high-res screenshot.
Message 13 of 18
the path bad/incorrect or something??
Message 14 of 18
TheCADnoob
I cannot say for certain. Ive had issues with network paths and long path names though im not sure those were CAD issues. I have heard the jpgs are tricky some times as well.
You can try reattaching them if you would like but first i would just try to see if toggling between absolute and relative paths makes a difference. To make it an absolute path again just copy the location of the file from explorer.
CADnoob
Message 15 of 18
Message 16 of 18
TheCADnoob
It looks like there are several duplicates in there. I don't think that's part of the problem but i would remove them if you could.
CADnoob
Message 17 of 18
sowhen i would attach the ref the attach image box would open. in it was a path option>>relative/full/no. i selected full and have had no problems since. thanks everyone for the help today. it is greatly appreciated
Message 18 of 18
TheCADnoob
Glad we could get it worked out!Smiley Happy
If you are satisfied with an answer mark it as the solution so others can use it for future reference.
CADnoob
