Highlighted Block Image
Message 1 of 13
Hi All
I using AutoCad 2013, and must have hit the wrong two keys by mistake.
Somehow, I've lost the highlighted image of a block before I insert it in the
drawing.
Any Ideas or Suggestions would be most helpful and appreciated.
Dave
Northern California
Replies (12)
Message 2 of 13
Alfred.NESWADBA
Can you please show a screenshot?
I have no idea where you should see anything highlighted BEFORE you insert it.
Please describe the command you use and the step-by-step description of what you see and what you expect.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 13
Couldn't really get a screen shot but what I'm trying to get back is
a command the helps you place the block on your drawing. The block
(like a kitchen sink) picked from your block library, then the block is
highlighted -ghost image and then you can see where it is about  to be
positioned. All I'm seeing is just a blank screen. hope that made better sense.
Like your Dog
Dave
Northern California
Message 4 of 13
Alfred.NESWADBA
>> The block (like a kitchen sink) picked from your block library
How do you insert a block from your library into the current drawing? Using ...
  • Windows Explorer
  • Design Center
  • ToolPalette
  • Command _INSERT?
This might already help: make sure your system-variable DRAGMODE is set to "Auto"
- alfred -
Alfred NESWADBA
Message 5 of 13
Thanks for your quick reply, I was out of the office today.
I use the insert command to place blocks and dragmode was in Auto.
Still no change
I appreciate all your input
Dave
Message 6 of 13
Hi again, I went on You_Tube and here is a screen shot of what I am experiencing when I try to insert a block
From the picture you can see the block on the right is about to be inserted (cursor is visible) In my case the cursor
is visible but the block is not
Dave
Message 7 of 13
Alfred.NESWADBA
can you please
  • start a new drawing
  • in that drawing create a new block from just a few lines
  • then insert that block
Do you have here the same issue?
If yes ... please login with a different/new Windows user account and try the same again ... also no dragging visible?
- alfred -
Alfred NESWADBA
Message 8 of 13
neaton
Changing DRAGMODE to Auto should bring back the preview. Type DRAGMODE at the command line and choose Auto from the three choices of On, Off or Auto.
Nancy
Message 9 of 13
Ok That Worked just Great- New Drawing, New Block worked like it's suppose too.
Thanks. Any ideas on how to make it work on my present drawing?
Dragmode is still set to Auto
Message 10 of 13
Alfred.NESWADBA
May be the block is much to large or very very tiny while you insert it? Zoom in and out while you are in the insertion mode (while AutoCAD asks for an insertion point).
Other idea: the layers are off or frozen, layers of parts within the block or the current layer is off?
You might upload the drawing and let us know which block don't work well during insertion.
- alfred -
Alfred NESWADBA
Message 11 of 13
Hi Alfred
First I'd like to express my gratitude to you, with all your helpful suggestionsI tried all the last ideas all with negative results. The image feature ininserting a block is nice to have but it's not critical in delaying anyon going projects, it's just nice to have.
The funny thing is, that when I started this present job, it worked perfectly as it was supposetoo but for unseen reason it just stopped working.
My first thought was, that I typed in a wrong two letter command that turned that feature off and that it was an easy fix by requesting the right two letter commands again to have itturned back on. apparently this is not the case.
I'm still happy to try any further ideas or suggestions
Takes for all your help
David Shepherd
Northern California   #- Please type your reply above this line -##
Message 12 of 13
Hi
Thanks for replying my request for help.
Yes, that was one on the first thing I tried
and unfortunately, dragmode was set in auto
David Shepherd
Message 13 of 13
Alfred.NESWADBA
As all is working well with a new drawing it seems to depend on a specific dwg and settings in that dwg-file.
So can you please upload this drawing and let us know which block-name you'd like to insert?
- alfred -
Alfred NESWADBA
