I'd like to hide point cloud in a viewport so I changed the Visual Style to "2D Wireframe". The point cloud became a text. Is there any way to hide the text?
Solved by john.vellek. Go to Solution.
Solved by j.palmeL29YX. Go to Solution.
Hi @2011301610406,
Can you not just freeze the layer that the point cloud is inserted upon? That is likely the easiest way I can think of to hide the point cloud data.
Hi @2011301610406,
Sorry, I may not express my problem clearly.What I want is hide Pointcloud in one Viewport and keep it show in another. If I freeze the layer, the point cloud is hidden from all the viewports.
Hi @2011301610406,
Try this please. Go to the viewport where you do not want to see the Point Cloud data and double-click so you are in model space inside the viewport. Now select the Freeze Layer icon from the ribbon. This should freeze that layer just in that viewport.
You can also select the layer while in the viewport and set the VP Freeze state to frozen for the current viewport.
Hi @2011301610406,
I know what you have mentioned, but I notice that it can only work when "TileMode" is set to 0 as shown below.
How to make it work when "TileMode" is set to 1?
With TILEMODE=1 it's not possible to hide objects in only one of the viewports (while the same view direction).
And also you can't not modify the objects in a different manner in different viewports.
cadder
Jürgen Palme
cadder
Jürgen Palme
Hi @2011301610406,
I am checking back to see if my post or @j.palmeL29YX's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Hi @2011301610406,
