AutoCAD Forum
Hemisphere Drawings
2 REPLIES 2
758 Views, 2 Replies
Hemisphere Drawings
Hi everyone,
Any idea on how to create the hemisphere solid shape (circled in red)?
Gan
Hemisphere Drawings
Hi everyone,
Gan
2 REPLIES 2
imadHabash
imadHabash
as seen from below image ... draw the base by array ( Polar ) the triangle shape . the idea is to draw one edge then Array it again as extruded element.
Imad Habash
Imad Habash
leeminardi
leeminardi
Here's another method that I think gives you a better top.
Create two arcs as follows.
Assuming the final design has 16 flutes rotate one of the lines by 11.25°  (360/32) about the vertical axis and then loft them the two lines.
Use 3dnirror to make the opposite surface and then make a polar array of the two surfaces specifying 16 items.
lee.minardi
lee.minardi
AutoCAD Inside the Factory
