AutoCAD Forum
Help.
4 REPLIES 4
apanbasu
518 Views, 4 Replies
Help.
I am trying to post for help. I have type AutoCad 2008, TXT2Mtxt in Subject line and an error message came in stating the subject is not suitable for the Discussion group and rejected. After a while it stated that same message have been submitted many time and the system is overload or something like that.
What is happening?
This is was my post.
Is there a way we can combine several mtexts to ine Mtext.? I tried TXt2Mtxt, Tried copy paste to firts Mtxt to the second mtext. Nothing worked. Will not paste in the ddedit window.
Any help will be highly appreciated.
4 REPLIES 4
pendean
in reply to: apanbasu
You need more than the core commands to do that: post and ask in the LISP forums for guidance while you wait here.
Customization Discussion area:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Try exploding all the mtexts to dtext and then use TXT2MTXT to put them all together again.
Hope that helps!
John
apanbasu
Thank you and it worked.
Jay_B
Please don't forget to mark the post that solved your issue "Accept as Solution."
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Forma Design Contest
