Help!
Help!
zac_bullock
Message 1 of 33
Help!
zac_bullock
When I open a specific type of drawing that has MTEXT in vertical fashion, my Autocad will automatically convert this into regular text and is horizontal. Why is it doing this? Also - when I zoom in to text on the screen, the "thickness" of the text scales up. As I zoom out, the text becomes a "block" of whatever color the text is.
Background: I have been messing around with CUI, creating my own CUI etc. I accidentally unloaded ACAD.CUI. After searching for it again, I was able to reload it. When I reloaded it, there were several more tabs than what I needed in CAD, so I removed them and saved the CUI to acad<myname>.cui and used it instead. I don't know if this is why this is happening or not.
Do I just need to reload the original acad.cui? Thanks hopefully someone knows what I am needing 😞
Replies (32)
Message 21 of 33
zac_bullock
After searching on my computer it found the Simplex.shx file, but I deleted it and pasted it with the method you explained for my coworkers file, I have reset autocad and still not working
Message 22 of 33
pendean
Community Legend
Community Legend
@zac_bullock Open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
Message 23 of 33
zac_bullock
@zac_bullock - this post has been edited due to Community Rules & Etiquette violation.
I have a case open.
Message 24 of 33
zac_bullock
I did not mean that in a derogatory way towards you all. I am just frustrated I cannot solve my problem
Message 25 of 33
paullimapa
I'm able to replicate your problem:
What I did is look for the font mapping file & add this line on top:
simplex;simplex_.TTF
Which caused the problem
You can locate your acad.fmp file by doing the following at the AutoCAD command line:
(findfile"acad.fmp")
This file can be opened using Notepad & modified.
Perhaps try copying from the other computer's acad.fmp and replace yours or look for this line:
Remove it & save the revised file
Now exit AutoCAD & reopen and see if this fixes the problem which did it for me:
Paul Li
IT Specialist
@The Office
Message 26 of 33
zac_bullock
I'm happy to see you can recreate my problem, however, when I opened the font map file the line in question was not present so I could not delete it out.
Message 27 of 33
zac_bullock
I also had a coworker send me their font map file and I still have the same issue
Message 28 of 33
paullimapa
well, I'm out of ideas.
Paul Li
IT Specialist
@The Office
Message 29 of 33
zac_bullock
Darn 😞 Do you suggest resetting acad, I assume that is my only option...
Message 30 of 33
Patchy
Reset to default and get to work.
Message 31 of 33
zac_bullock
Thanks Patchy, I didn't want to go this route but alas this is seemingly a waste of time
Message 32 of 33
paullimapa
or give this one more try it's a long shot
edit the acad.fmp & add this as the top line to see if it makes a difference:
simplex;simplex.shx
Paul Li
IT Specialist
@The Office
Message 33 of 33
zac_bullock
It's too late I already reset! No worries though I won't be making the same mistake again. Thank you for the replies and help today.
