Hi all
I want to ask for somehelp on qleaders. Bascially I want to write the text in the first screenshot in three lines. However when I type the text with three enters. I get the following. Can anyone explain what is happening?
Hi all
Solved by imadHabash. Go to Solution.
i think that you can get it from selecting proper settings as seen below
Command: QLEADER
Specify first leader point, or [Settings] <Settings>: s
Imad Habash
Command: QLEADER
Imad Habash
@Anonymous wrote:
Sorry I don't think that works. The point is at the correct place Im having issues with the text
hope it's help ...
Imad Habash
hope it's help ...
Imad Habash
Here it works (tested in ACAD 2018 and 2016):
Maybe you typed a text width to small? (You should confirm the 0 with ENTER)
cadder
Jürgen Palme
cadder
Jürgen Palme
Why not just use MultiLeader instead of QLeader a command from 20+ years ago?
Nick DiPietro
Cad Manager/Monkey
Nick DiPietro
Cad Manager/Monkey
