AutoCAD Forum
Help with Qleaders
5 REPLIES 5
396 Views, 5 Replies
Help with Qleaders
Hi all
I want to ask for somehelp on qleaders. Bascially I want to write the text in the first screenshot in three lines. However when I type the text with three enters. I get the following. Can anyone explain what is happening?
5 REPLIES 5
imadHabash
i think that you can get it from selecting proper settings as seen below
Command: QLEADER
Specify first leader point, or [Settings] <Settings>: s
Imad Habash
in reply to: imadHabash
Sorry I don't think that works. The point is at the correct place Im having issues with the text
imadHabash
hope it's help ...
Imad Habash
j.palmeL29YX
Here it works (tested in ACAD 2018 and 2016):
https://autode.sk/2KQtVqV
Maybe you typed a text width to small? (You should confirm the 0 with ENTER)
cadder
Jürgen Palme
gotphish001
Why not just use MultiLeader instead of QLeader a command from 20+ years ago?
Nick DiPietro
Cad Manager/Monkey
AutoCAD Inside the Factory
