help with dynamic input UI size
while working on a project the UI size of dynamic input blew up on me ... I have no idea why or how which in turns makes me unable to bring it back to its former self.
as they say a picture is worth a thousand word , the top example is how it normally looks like (taken from a different project)  the bottom example is what I'm currently dealing with.
while taking these screenshots I noticed that the polar tracking is also different , no idea if it makes a difference
imadHabash
i suggest from DDUNITS command to change length type .
Imad Habash
my units are set properly and are identical to all of my other projects. it appears as if its strictly the UI that changed in size  for that one command only.
I did find a workaround, basically copy/paste everything I have from that project to a new file,  it only affects that one file for what ever reason .
sure it doesn't fix the problem , I still don't know how to actually fix it if it happens again but at least I'm able to work without it driving me crazy lol.
rkmcswain
I don't see the difference, other than your UNITS are set differently.
strictly look at the UI (user interface)  beside the measurement of the line there is 2 circles ... the top example shows the regular size of the dynamic input UI
the 2nd example the circles are 10x bigger the UI changed in size somehow
