Help with 3D drawing assignment
AutoCAD_Oozer
AutoCAD_Oozer
Hi I am currently figuring out the 3D aspects of ACAD, I am tasked with representing a hole in concrete with layers of gravel and dirt. I am hoping it’s easier to do this in 3D. What is the best way to represent the image in the attached file in CAD, is it using 3D or 2D?
dany_rochefort
2D...  Your gonna need a Plan view and a Section AA across the center of your Plan view to detail your cross section layers.  No point in doing that in 3D, although you could for educational purposes... But in an engineering office you won't see such a detail in 3d.
Patchy
2d and get it done fast, if you have time then use 3d
To hatch, see this:
https://www.google.com/search?q=hatch+3d+with+gravel+autocad&client=firefox-b-1-d&channel=tus5&sxsrf...
or use Material.
Valentin_CAD
@AutoCAD_Oozer ,
In addition, you could always provide an isometric view with your 2D orthographic drawing.
Check out Autodesk Webinars (link) for additional help on 2D or 3D.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
dany_rochefort
