Autocad Command to make object automatically break lines [SOLVED]
Topejas
Topejas
Need help with making objects automatically break other lines. See example below
I know there is a function that when I place my vertical rectangle it will auto break the horizontal one, and when I move my vertical rectangle, the horizontal will then be "unbreaked" again.
Help appreciated
Topejas
I found the solution, using the Wipeout command on the block!
