I've been working on Vectorworks for the past 7 years and have a pretty solid understanding of the software.
Anyway, I've got an upcoming job interview for a position that would be perfect for me.. the only worry is it's autoCAD based. I've been playing around with the trial today and whilst it mostly seems straightforward, it can be quite frustrating learning over again. I'm usually a fairly speedy learner when it comes to this sort of thing, so I'm sure it's just a matter of perseverance.
What I'm wondering is if anybody has made the same transition as me? And if so, any tips or resources you could share?
Thanks in advance!
Welcome to the community!
You can check at https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-39B76D69-225D-45EE-A9AC-59CCBF48AF64
https://www.youtube.com/@sourcecad
....the only worry is it's autoCAD based....
There is always going to be a learning curve, and nope, you're not going to get it in a day or week or month. Sorry. That's just the reality of it all. Your ability to forget VW is going to help a lot though, you'll eventually get there.
If they only use plain AutoCAD (but not the ARCHITECTURE version which is closer to VW in at least many of the ideas) your struggle is going to be even tougher. Unless they purchased or created a lot of customizations. Plain AutoCAD only draws "dumb" lines, literally. VW is not that.
