Help please! Dimensions not showing up in Viewport PS, layer not frozen
Help please, new to CAD this year while studying.
Have come across issue: Dimensions not showing up in Viewport PS but do in my model, and the layer is not frozen.
I want them to display in viewport and have tried searching for solution, there was one that suggested thawing a layer, only mine isn't frozen. Any other suggestions?
MikeKovacik4928
What has happened,  is that you are using an annotative dimension style
and the annotative scale of your dimension is not the same as the scale of your
viewport
2 choices to rectify this
1. Make the annotative scale of your dimension the same as the scale of your viewport
2. Make the dimension non annotative and scale up the features using "dim scale overall"
    to match the viewport scale, otherwise the text and arrowheads will be too small to read
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Higher Diploma Mechanical Engineering
Certified Autocad 2013 & Inventor 2013 Professional
Authorised Autodesk Trainer
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
^^Thank you soooo much! This has helped.
