Help me with drawing - Array - AutoCAD 2022
gukuvegetasherif23
Observer Observer
Message 1 of 8
gukuvegetasherif23
Observer
Observer
I tried using the hexagon edge as a base of the circle but it seems wrong and i think i use polar array to complete the rest
@gukuvegetasherif23 Your post title was modified to add the product name and version and to increase findability - CGBenner
Accepted solutions (3)
Replies (7)
Message 2 of 8
imadHabash
You draw the circle to reach to the edge of base hexagon; you should draw it for the middle!!
The trick in my solution is to find angle 120° which represents the interior angle of the base hexagon or draw lines perpendicular to base hexagon.
Imad Habash
Message 3 of 8
parkr4st
Attached .dwg
Two hexes.  POLYLINE 1 to 2 straight, arc to 3 line to 4 and arc to 1 and close.
OFFSET to corner of inner hex for the inner line and ARRAYPOLAR
Message 4 of 8
vinodkl
https://forums.autodesk.com/t5/autocad-forum/help-me-with-my-drawing/m-p/13796187#:~:text=Please%20t...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 8
CGBenner
@gukuvegetasherif23
Hello, do you still need help with this question?
Chris Benner
Message 6 of 8
gukuvegetasherif23
Observer
Observer
Thx the previous replies answered my question
If u can help me with this it will be much appreciated i tried to tk to make the cirlce but it didn't work so what should method should i use to draw it
Message 7 of 8
parkr4st
layout some xlines for guides per the dimension.  draw the outer ellipse  60 x 164 units.  offset 3 units inward x2 for two inner ellipses.  center ellips intersect 60 units offset xline for circle centers.  two circles and trim away unwanted lines and arcs, etc.  erase xlines & middle elleipse and rotate and array as asked for.
Message 8 of 8
imadHabash
Hi @gukuvegetasherif23
Click on below image and see how it works ....
Imad Habash
