HELP Layer properties with red X over it
Has any one seen this and why does it happen?!?!?!?!?!!??!?!
vinodkl
Check if your 3DCONFIG is turned on. I guess it the problem with the graphics as its taking time to refresh screen.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
This is what I see
vinodkl
Hmm. I still suspect the problem is due to graphic card, try updating the drivers. meanwhile Try the Classic view. Type in command CLASSICLAYER.
Ill try that, but its a brand new computer only about a month on it. With some power behind it might I add.
Seth
