Difficulty in removing File References Bar
GoodDay fellow AutoCAD community.
I'm a student, stuck on a issue no one around my community seems to have an answer for on AutoCAD 2017 version. The issue is;By unfortunate means I created a pathway Bar for file references
on my Template drawing Home pages without meaning to. This File Reference bar is positioned right above my Tools Bar, making my drawing screen at the bottom quiet small.
"How do I remove this File Reference Bar, , please assist me?"
File Reference bar provides Details in Vertical of the Drawing you are currently editing then....
Thank you
Khwezi
scot-65
Have you tried:
Command LOCKUI --> 0
to make the docked/floating window accessible?
-or-
Command REFCLOSE
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Alfred.NESWADBA
And if it is not locked then click and hold your left mousebutton at the point marked as rectangle and move it into the direction like the arrow shows until it does not show the window-locked preview rectangle.
You can also right-click at that position and disable "allow docking".
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks Mr Alfred. Worked. Just pressed the side of the Bar then it narrowed the bar and gave a Cross-close option at the side.
Thanks and kind regards
Khwezi (Architecture student)
Thanks for the assistance Sir. Unfortunately wasn't knowledgeable to know your shortcut routine solutions.
