Help creating contour and boundary from dwg file from GIS software
smorrismath
smorrismath
I have trial versions of Auto Cad 2023 and Auto Cad 2023 3D.  I am trying to make a contour map.  For days, I have read numerous how-to articles in the Autodesk community on the web.  But I can't find Prospector or Toolspace.  I am pretty sure I have the points imported, though some aren't showing their descriptions and I exploded the block.
If someone can look at what I have done and tell me the steps to finish this project I would greatly appreciate your effort.
Replies (12)
pendean
Community Legend
Community Legend
Greetings @smorrismath
What is "...Auto Cad 2023 3D" please? Do you mean the separate software called Civil3D? Or Map3D?
or do you mean something else?
ChicagoLooper
Hi @smorrismath
You're using plain vanilla AutoCAD.
Toolspace and the Prospector tab are in AutoCAD Civil 3D.
Civil 3D trial versions and Student versions can be found >>HERE.<<
Chicagolooper
Pointdump
Hi Sharon,
Where is "6 15 23 2570 athens hwy 129 points.txt"? Can you post that file?
Your drawing is assigned GAHP-WF coordinate system, but the linework is helengone to the west of the extents of that coordinate system.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
ChicagoLooper
Hi @Pointdump
EPSG 2239
You can try downloading elevation data HERE.
Then do like this:
Then Unzip File=>MapImport=>Create Object Data=>'Raise' contours based on OD Elev <<OK to raise manually w/o query>>
Next, Toolspace=>Create EG=>Definition=>Select the imported Contours=>Add Boundary.
Optional:
Surface=>Contextual Ribbon=>Surface Tools=>Extract from Surface=>Extract Objects=>Major & Minor contours
Chicagolooper
smorrismath
1,1487457.378,232329.324,880.383,SS Gravel line 40 in
2,1487447.334,232430.754,879.625,HYDRANT
3,1487441.667,232430.232,879.512,POWER
4,1487463.899,232527.809,878.874,HC1
5,1487457.664,232515.011,877.884,HC1
6,1487467.555,232538.560,880.518,PIN
7,1487480.963,232531.627,879.162,POWER
8,1487422.247,232550.237,879.038,METER
9,1487419.125,232550.525,878.730,METER
10,1487417.525,232546.794,879.240,HC1
11,1487405.101,232556.121,878.510,SS1 C35 IN BT L
12,1487398.088,232567.984,877.394,WATER LINE
13,1487384.877,232563.053,878.615,STORAGE
14,1487386.856,232572.376,878.090,STORAGE
15,1487379.180,232574.269,877.836,STORAGE
16,1487376.547,232564.546,878.068,STORAGE
17,1487359.349,232562.532,875.363,POWER
18,1487374.695,232582.128,876.365,PL
19,1487363.111,232530.417,878.309,HC2
20,1487407.882,232524.019,879.383,HC2
21,1487405.996,232511.191,879.624,HC2
22,1487413.886,232525.417,879.559,DRIVE
23,1487407.718,232490.603,879.559,DRIVE
24,1487415.977,232484.889,879.615,HC3
25,1487415.232,232470.461,879.485,HC3
26,1487356.522,232467.936,877.471,METER 3 From Power Pole2
27,1487348.765,232474.507,877.573,HC3
28,1487352.734,232466.946,877.216,CLEAN OUT
29,1487354.308,232448.065,877.854,HC4
30,1487353.436,232433.614,877.912,HC4
31,1487376.458,232458.241,877.951,SS 2 GRAVEL LINE 40 IN
32,1487408.122,232456.046,878.826,DRIVE
33,1487410.586,232444.635,878.734,DRIVE
34,1487440.986,232443.976,879.831,DRIVE
35,1487435.168,232458.218,879.382,DRIVE
36,1487434.738,232468.066,879.386,DRIVE
37,1487431.520,232474.312,879.619,DRIVE
38,1487456.889,232503.365,877.406,DRIVE
39,1487471.989,232502.114,876.953,DRIVE
40,1487487.472,232497.988,875.712,DRIVE
41,1487519.981,232500.404,872.906,DRIVE
42,1487541.747,232511.620,872.481,DRIVE
43,1487565.516,232504.193,872.424,DRIVE
44,1487538.270,232485.818,873.121,DRIVE
45,1487524.737,232475.322,873.928,DRIVE
46,1487517.729,232465.020,875.299,DRIVE
47,1487549.703,232442.103,877.238,DRIVE
48,1487531.090,232417.356,877.352,DRIVE
49,1487512.377,232425.346,877.212,DRIVE
50,1487504.700,232422.021,877.402,DRIVE
51,1487503.635,232410.433,877.506,DRIVE
52,1487505.101,232404.988,877.705,DRIVE
53,1487527.078,232387.393,877.816,DRIVE
54,1487523.631,232372.155,878.023,DRIVE
55,1487501.363,232387.532,877.375,DRIVE
56,1487492.408,232396.078,877.526,DRIVE
57,1487482.307,232412.978,877.684,DRIVE
58,1487477.678,232420.331,878.332,DRIVE
59,1487474.467,232420.156,878.831,DRIVE
60,1487472.576,232409.566,879.526,DRIVE
61,1487474.038,232393.854,879.960,DRIVE
62,1487482.558,232371.718,879.821,DRIVE
63,1487494.288,232349.383,881.409,DRIVE
64,1487502.300,232330.125,881.252,DRIVE
65,1487510.261,232333.862,882.775,DRIVE
66,1487536.280,232305.504,880.729,DRIVE
67,1487552.054,232301.369,882.667,DRIVE
68,1487561.975,232271.526,882.974,DRIVE
69,1487525.725,232289.229,880.648,DRIVE
70,1487497.723,232313.139,880.674,DRIVE
71,1487473.579,232339.723,880.103,DRIVE
73,1487448.170,232406.009,879.380,DRIVE
74,1487441.766,232394.120,878.621,DRIVE
75,1487425.406,232384.953,878.356,DRIVE
76,1487382.826,232374.876,876.734,DRIVE
77,1487385.248,232366.223,876.534,DRIVE
78,1487415.410,232373.503,877.085,DRIVE
79,1487369.526,232341.255,877.030,SS4C
80,1487418.489,232346.059,877.043,SS5 C L
81,1487453.677,232330.033,878.127,SS6 GRAVEL 29 IN
82,1487485.143,232313.488,880.438,SS6
83,1487420.766,232346.984,877.435,SS4 C 0- 5L
84,1487344.138,232328.157,878.867,PIN
85,1487415.063,232389.266,878.156,HC5
86,1487366.706,232379.514,876.869,HC5
87,1487363.892,232393.786,877.454,HC5
88,1487346.856,232405.943,877.417,SS7 PAC
89,1487433.216,232429.912,878.868,SS8 C L
90,1487381.829,232491.640,878.163,SS9 C
91,1487495.402,232371.789,877.752,SS10 CUT
92,1487555.034,232339.477,879.519,SS12 CUT STONEY CR
93,1487565.935,232350.668,880.047,POWER
94,1487573.179,232368.533,879.177,METER
95,1487582.564,232388.514,878.132,METER
96,1487568.087,232378.151,877.924,HC6
97,1487559.755,232366.703,878.393,HC6
98,1487522.082,232394.730,876.547,HC6
99,1487530.448,232405.864,877.011,HC6
100,1487537.155,232419.221,877.391,HC7
101,1487580.297,232390.236,879.555,HC7
102,1487589.320,232402.890,879.410,HC7
103,1487594.206,232415.731,880.086,HC8
smorrismath
Thank you
smorrismath
AutoCad Map 3D I am so sorry. Still learning from the two trial softwares,
obviously, I have a lot to learn
Thank you
ChicagoLooper
@smorrismath
FYI, point #72 is not in the point list.
jus sayin'
Chicagolooper
smorrismath
Thank you so much for your help.  I will follow the steps!
smorrismath
I will check that in the GPS data collector, thanks.
smorrismath
Thanks I have downloaded the shape file in AutoCad Map 3D, but I still can't get Toolspace - when I type the command I get the same error, not found.
smorrismath
Also, my 87-year-old Dad is in hospital, I am leaving to go check on him, I will work on this again tonight or early tomorrow.  Thank you again for your help.
Sharon
Type a product name
