AutoCAD Forum
Help adding a new key
10 REPLIES 10
Message 1 of 11
bekhit
505 Views, 10 Replies
[This post was moved from on older thread to this new thread and the title modified - CGBenner, 7/22/2024]
why I couldn't find on my right side list the access line to be able to add new key ?
can you help ?
Thnx
10 REPLIES 10
Message 2 of 11
TomBeauford
in reply to: bekhit
You need to come up with an AutoCAD term for what you're looking for and what you want it to do.
Are you talking about a keyboard shortcut or toggle? What is the "right side list" you're talking about?
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 3 of 11
Patchy
in reply to: TomBeauford
The old dinosaur:
Message 4 of 11
TomBeauford
in reply to: bekhit
Old DOS days! Remember the Cursor menus?
2023
Message 5 of 11
jskalaXDDX5
in reply to: bekhit
If you are wanting to add a Command to the Shortcut (Right Click, Contextual) menus you can change all of that through the CUI.  Really great video here:
https://www.youtube.com/watch?v=0B8KuHHuiqM
Message 6 of 11
Patchy
or the Digitizer with 16 buttons.
Message 7 of 11
bekhit
in reply to: bekhit
thanks for replying and sorry that my question wasn't clear to understand,
this what I meant, I can't add key in that menu
sorry because my autocad is german version
Message 8 of 11
cadffm
in reply to: bekhit
what do you mean with "new" ?? This field contain the sequenz of keystrokes.
You press the button and the button sends this "menu macro" to the commandline.
What happens if you try to edit
a) this field
b) another field of this "command", for example the name (please redo it after the test)
You can edit the whole macro and all other properties.
IF
you have writeright to this .cuix file
and the cuix is not attached as enterprise cuix.
But why do you want to change the macro in this case.
Mitte zwischen 2 Pukten start the m2p object selection method, what other command can be useful?
I guess, you want a totally different thing, like to have another name for it, an alternate to m2p
Sebastian
Message 9 of 11
bekhit
in reply to: cadffm
I just need to set m2p to F(key), but my list in CUI doesn't have add key as I attached in Photo.
Message 10 of 11
cadffm
in reply to: bekhit
okay,
don't edit the "command" and espacially not the macro properrty.
You have to add the "command"  from the lower left section to TASTATURBEFEHLE/TASTATURKÜRZEL on the upper left section.
Drag&Drop or contextmenu COPY and contectmenu PASTE will work to do that.
Under Tastaturkürzel you can add the F(key),
but think about: The F(key) is already in use for enother function.
Sebastian
Message 11 of 11
bekhit
in reply to: cadffm
thanks
Forma Design Contest
AutoCAD Beta
