AutoCAD Forum
Heidi Error causing Fatal error
5 REPLIES 5
Joe-Bouza
471 Views, 5 Replies
I posted my issue >>>HERE<<< because I could find this forum.
An now I am getting desperate.
Joe Bouza
5 REPLIES 5
wispoxy
in reply to: Joe-Bouza
I will stay with you and make sure this problem gets resolved.
  • What Autodesk Product and Version are you using?
  • Is your current Windows 7 OS and Autodesk Product fully up-to-date / updated?
pendean
Id resetting 2014 doesn't clear up the problem, try a repair reinstall and answer yes to replace files (back up all customizations first): you have a bad or corrupt installation if this is not an inherit C3D problem as noted by your peers over in that forum.
Joe-Bouza
in reply to: pendean
did the repair reinstall and still got the error, but this morning I logged in, started c3d and the previous error did not surface. Kind of weird but I'm running so that must be good
Joe Bouza
Joe-Bouza
in reply to: wispoxy
2014 isdp
win 7
see may last thread
Joe Bouza
Joe-Bouza
Driver update appears to have fixed it
Joe Bouza
AutoCAD Inside the Factory
