Hatch settings does not give a 'use current' option for Hatch Colour
htoolwepawk
Message 1 of 8
htoolwepawk
I want to fill the circle with a hatch pattern however the solid colour is blocking it. There is no options for 'use current' to allow me to have the hatch pattern. It is under a layer with a continuous linetype and white colour.
Replies (7)
Message 2 of 8
paullimapa
This is when it's important to show the Command line window so you can see the prompts and select the additional choices:
Now you can click on seTtings to open up the Hatch and Gradient dialog box:
Under Type & Pattern you can make the selections you want including Use Current for Color
Also by clicking on the arrow in the lower right hand corner you can see even more options to select from:
Paul Li
IT Specialist
@The Office
Message 3 of 8
cadffm
@htoolwepawk
Looks like a wrong scale, that's all (guessing)
Draw a circle with rad=100 and try it again.
Feel free to share your .dwg, so we can test and show the problem.
@paullimapa
If you think he is talking about the issue is about hatch pattern and hatch color, both are available in ribbon too.
Sebastian
Message 4 of 8
cadffm
About the "use current" color: The option is available, but not working as expected. This Bug appeared 10 versions ago.
But: It works correctly if you set PROPERTYPREVIEW off (many thx to @BeekeeCZ)
Sebastian
Message 5 of 8
paullimapa
Since OP specifically requested for 'use current' option for Hatch Colour", this is the issue.
This option only shows up once on the ribbon after entering the Hatch command without selecting any objects:
But after an object is selected or a point within the Circle is picked then that option is gone on the ribbon:
But when you click on seTtings to bring up the Hatch and Gradient dialog box, then that's where you still can have the option to select Use Current:
Paul Li
IT Specialist
@The Office
Message 6 of 8
pendean
Community Legend
Community Legend
@htoolwepawk Where is your commandline please? Thank would tell us more in your image. You cannot ever hide it all the time either, this is not the program to do so, you are missing out on program feedback.
Message 7 of 8
htoolwepawk
Yes, you understood my issue well, I understand now. Thank you Paul Li and everyone.
Message 8 of 8
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
