Hatch overrides funiture when copied from a different file
Message 1 of 12
Hi guys
Im trying to copy some funiture form one file to another file. When i do that the hatch pattern overides the lines of the funiture. Someone knows how to fix this? See before/after pics attched.
Thanks in advance!
before:
After:
Replies (11)
Message 2 of 12
imadHabash
can we have both CAD files ( before / After ) , even with one block ?
Imad Habash
Message 3 of 12
chriscowgill7373
are lineweights set to be displayed in one file vs the other?  As @imadHabash said, it would be more helpful to have example drawings, as you cant tell anything from your picture.
LW will open this dialog box
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 4 of 12
Here are the before and after files 🙂 Thanks
Message 5 of 12
Hi
thanks for the answer but it didn´t work...
I´ve attched the files in the piroir messenge.
Message 6 of 12
Kent1Cooper
My impression has been that when copying multiple things, the order of the copies comes out reversed from the order of the source objects.  But I think that may be version-dependent -- I can't seem to get it to work that way in Acad2019.
The HATCHTOBACK command will quickly fix that.  Also look into the HPDRAWORDER System Variable.
[Never mind, I think -- I didn't realize the Hatch patterns are parts of the Blocks.  My recollection may apply if they're separate from the outlining linework, but probably not in this case.]
Kent Cooper, AIA
Message 7 of 12
chriscowgill7373
Thank you for the drawings, it clears it up.  You are referring to the draw order of the hatch and the linework.
What version of AutoCAD are you running?  Can you provide a screenshot of the dialog that appears when you type ABOUT <enter> at the command line?
Message 8 of 12
Here you go 🙂
Message 9 of 12
imadHabash
when i open your drawings i receive the below image , But i can tell that if you take all of your CAD elements from After.dwg to a new empty CAD file it will works fine as i tested here . see attached CAD file .
Imad Habash
Message 10 of 12
Hi, thank you!
That will work. But how do i do that without useing copy/paste?
Message 11 of 12
imadHabash
i don't know how did you make or prepare those blocks . i explode those blocks then i insert them again in After.dwg and it's work fine .
Imad Habash
Message 12 of 12
chriscowgill7373
@Anonymous wrote:
Here you go 🙂
Thanks for your about dialog.  2019 had an issue when it was first released with draw order.  I would recommend getting the latest updates installed. then try copy and paste into a new file and see if the issue continues.
You can get the updates from your Autodesk Account manage.autodesk.com or from the Desktop App.
You should be on 2019.1.2
