Hatch menu
Hatch menu
rcook
Message 1 of 19
Hatch menu
rcook
I just upgraded to 2017 last week - I know fun, fun.  I have some hatching in a drawing I had that I am trying to change some properties such as transparency, pattern etc.  I do not get the hatch creation menu that I used to get (in ribbon) when I edited a hatch pattern.  I only get the menus when I create a hatch.  what's up?
Replies (18)
Message 2 of 19
rkmcswain
Check this setting in OPTIONS.
If not that, then check this out.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 19
rcook
Where would that be found in the options? The only hatch selections in options is associative hatch and ignore hatch in snap.
robert
Message 4 of 19
rkmcswain
Do you not see the inline image? It's clearly marked on there.
Message 5 of 19
pendean
Community Legend
Community Legend
Click on image below to enlarge
Message 6 of 19
rcook
I do not have the 3 options to select so I guess "no I didn't see" is the obvious answer.  all I have in my selections is Retain pickfirst.... and object selection max...
Message 7 of 19
rkmcswain
My bad @Anonymous. I was using 2014 to make that screenshot. You're right, 2017 is different because they changed the way it works.
Is it possible that the menu file has been modified and that the contextual tab was removed?
Message 8 of 19
GrantsPirate
I am running 2017.1 and I don't see those choices either.
Maybe you need to change the CUI setting.  See image.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 9 of 19
john.vellek
Hi @rcook,
Even thought that ribbon looks like it wants you to create a new hatch it works on your existing ones too. I made a quick video showing an existing hatch in my drawing. When I select it the ribbon shows up for hatches. When I make any changes in the ribbon hatch settings they are reflected in the selected hatch.
Is this what you wanted or did I misunderstand the question?
John Vellek
Message 10 of 19
rcook
John,
That sounds like what I am looking for. I get the ribbon when I choose to create a hatch but I do not see the hatch ribbon when I select an existing hatch. I am not sure what the video shows because I can't find it, but it is still early this morning and I am not a morning person.
Robert
Message 11 of 19
rkmcswain
I don't think @john.vellek understood your original question.
In the meantime, while you try and figure this out, can you run the command HATCHEDIT, select the hatch object, and then make your changes?
Message 12 of 19
rcook
Rkmcswain,
Yes, I have been working around this issue, I typically use ribbons so I am more comfortable with them vs typed commands.
Robert
Message 13 of 19
rkmcswain
Understood @Anonymous.
I didn't see a reply to an earlier question -> "Is it possible that the menu file has been modified and that the contextual tab was removed?"
To go along with this, have you verified that the Hatch Contextual Tab is enabled in the CUI?
Message 14 of 19
rcook
The contextual tab is there, the 3 selections are not there - where you noted to select show on single click. All that shows are the retain .... Selection and object selection max...
Robert
Message 15 of 19
john.vellek
Hi @rcook,
If you haven't made a lot of customizations, why don't you reset your CUI to see if that helps?
John Vellek
Message 16 of 19
rkmcswain
I know the 3 selections are not there. Maybe you missed my earlier reply when I said I took that screenshot from 2014 (not 2017).
Take a look at this document on how to PREVENT contextual tabs from appearing. Maybe something on this list has been DONE on your system. (I know it says 2015, but this is when the behavior changed - it's the same in 2017).
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Message 17 of 19
rcook
I have looked at the contextual tab in the cui and the hatch creation is set to full with focus - this brings the ribbon up at hatch creation but not at selecting a hatch to edit.  If I set it to full w/o focus the hatch ribbon does not come up at all, even when creating a new hatch.  I have hatch selected in the contextual tab area but no selection to expand or add to it (not sure if it should have).
In answer to resetting to defaults - reset once on the front end - no luck.   I have made quite a few changes since and not ready yet to take the plunge again.
thanks for all the suggestions and help.
robert
Message 18 of 19
GrantsPirate
You will need to find the tab from the Ribbon - Tab section and drag it to the Hatch Selected Contextual tab area.
GrantsPirate
EXPERT ELITE MEMBER
Message 19 of 19
rcook
Excellent GiantsPirate!!!  That worked.   I have read that paragraph a couple of times but it did not click in my brain for some reason.
