Hatch is not visible in Model space or paper space
thehivedesignco
Message 1 of 10
thehivedesignco
Hi There,
I have been trying to hatch a portion of a wall with the concrete hatch. It is not annotative hatch, my drawing is not in an annotative scale at all. I can see one of my hatches that I did during another work session and it is at the correct scale. But, even when I try to copy this good hatch and stretch it accordingly to suit the new wall shape, it disappears.
I saw other posts about the annotative scale, but my hatch is not annotative, so I don't think this is the issue.
Please help!
Replies (9)
Message 2 of 10
jayhar
Enter new value for FILLMODE <1>
Turnoff GRAPHICSCONFIG
Jayhar
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 3 of 10
ennujozlagam
hello i agree with @jayhar,  if FILLMODE is set to  0 (Off), the hatch patterns will not be displayed. thanks
Message 4 of 10
beyoungjr
If you see a hatch pattern in one space of your drawing but not in another space of the same drawing I think your FILLMODE setting may not be a problem.
Do you see the hatch border for the one that has no pattern displayed?
  • In current versions of AutoCAD the "Hatch Editor" ribbon appears automatically when you select a hatch.
  • You can also edit the hatch with the Hatch Edit GUI by typing HATCHEDIT.
  • You may also use the -HATCHEDIT command to alter hatch settings from the command line (also appears in popup menus if Dynamic Input is on.
What happens when you attempt to edit the non-displayed hatch pattern or scale with one of the above methods?
Anything?
Maybe a screenshot of the hatch properties.
Post your file and we can try to help further.
Blaine
Blaine Young
Senior Engineering Technician, US Army
Message 5 of 10
s.borello
Are you able to post a sample file?
Message 6 of 10
thehivedesignco
Hi Blaine,
I checked the fillmode and it is set to '1'.
I cannot see the hatch border for my non-visible hatch. What is happening that with my hatch scale set to 1, I cannot see the hatch. When I set the hatch scale to 2, or 3, or 5 for example I can see the hatch but it is too large for what I want. Once I make it 1 or smaller scale it goes invisible. I have attached two screenshots. One with the hatch scale set at 1, and one with the hatch scale set at 4.
Message 7 of 10
thehivedesignco
Hi @jayhar ,
When I enter GRAPHICSCONFIG the properties box pops up that I have have attached in the image to the message. I'm not sure if I should disable my hardware acceleration. Will this cause my issues further down the road?
Message 8 of 10
thehivedesignco
@s.borello  I have attached the CAD file. It's not only the concrete hatch, it's any hatch which is not solid. The scales are all messed up.
Message 9 of 10
Alfred.NESWADBA
That is what I see:
I can also see that there are already 3 hatches created in that area.
You have got one suggestions, but I have not seen an answer for that ... have you used command _GRAPHICSCONFIG and turned off hardware acceleration?
Also please show us a screenshot of command _ABOUT so we see which version and update of AutoCAD you are working with.
You might also try to raise the setting of HPMAXLINES to 10000000 (and run _REGEN then).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 10 of 10
thehivedesignco
Hi @Alfred.NESWADBA  and all,
The solution was the HPMAXLINES scale. It was set to 100, so I changed it to 100000 and that worked!
Thanks everyone for your suggestions.
Justine
