I use very strict layer management in my drafting. Just lately, whenever I invoke the hatch command an unwanted layer is created. This layer does not fit my management system and I find it a bit annoying that this is happening.
Is it possible to turn this feature off? I would prefer that hatched entities are simply created on the current layer.
My guess is that you have a layer assigned to the variable HPLAYER. You can set it to . to use the current layer. Is this in every drawing? Maybe it is assigned in your template drawing or you have a lisp routine that runs at startup that sets this variable.
Thanks for that.
Actually I did manage to find the switch. It is under properties in the hatch command panel. There is a little arrow in the properties panel. Clicking it reveals the ONE property that's in there which is what default layer the hatch will be placed on. I set it to current and the problem was solved.
I'm not sure how I managed to accidently set it to some strange random layer in the first place though.
Thanks to all who offered suggestions. It was much appreciated.
it still does for me. i knew all those, and it changes itself, without me changing the assigned layer.
all i can think of is that either it gets data from another file where i copy-paste stuff and thinks itself that is the default or it tries to make sense of different layers of hatches and makes assumption each time you start the file to draw.
@korhan wrote:
.... or it tries to make sense of different layers of hatches and makes assumption each time you start the file to draw.
Probably that. [I don't think copy/pasting could cause it -- it would bring in the Layer if what you paste is on it, but it couldn't affect the Layer used for new Hatching.] Do you have an acaddoc.lsp file, or some other automatically-run thing such as in APPLOAD's Startup Suite or a .mnl file, that contains a setting for the HPLAYER System Variable? I find that HPLAYER can be set to a Layer that does not exist in the drawing, but if you do any Hatching, it will be created in the process.
Thanks for that, Kent.
None of them, and it is not creating a non-existent one. Some layer that is in the drawing, in one of the blocks hidden.
HPLAYER (System Variable) https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-8B64F625-7DD2-4264-8E59-3936F0992070
Specifies a default layer for new hatches and fills in the current drawing.
As it's Saved in each Drawing you need to set it in every Drawing or template Drawing to prevent it from happening again.
Initial value: use current
This control is available from the Hatch Editor contextual tab, Properties drop-down panel.
@korhan wrote:
... there is a probability that it changes that default without me fiddling.
You either have startup or add-in or 3rd party tool doing that for you, or someone else touching your files is changing things without realizing it: the majority of users do not have this issue so it's going to be hard for anyone over here to help you find your local culprit.
Start digging, and if needed, why not just create your our startup and/or reactor to always set this and any other variable to hat you want, or set up then use SYSVARMONITOR command with this variable (and any others) added to it's watchlist. There are so many active user ways to resolve local variable changing issues out there, let us know which you are most comfortable using.
Thanks Pendean.
I will check that (if I am skillful enough to be seen, and time).
You might have a point about startup. Nobody else has access to files. So, that leaves with your inital suggestions.
If I manage something I'll post to let anyone see.
