AutoCAD Forum
Hatch Changes to a different pattern whenever I try to add boundaries
4 REPLIES 4
swallis3DMS4
378 Views, 4 Replies
swallis3DMS4
Observer
Observer
As seen below, I have a residential that I'm trying to use a certain hatch pattern on. It won't let me create the brick pattern to the left and right of the door in the middle, so I copied and pasted from another view in the project. The pattern it won't let me create already exists in the project. When I tried to add the windows and door as new boundary objects, it automatically changes the pattern to a different brick pattern. It's not checked as annotative, and once I hit enter to finish the hatch edit, it won't let me change anything about the pattern. It's still the same scale, same layer, same everything EXCEPT the pattern I need. I'm really frustrated because I can't seem to figure out a solution through google or on my own.
4 REPLIES 4
pendean
in reply to: swallis3DMS4
pendean
Community Legend
Community Legend
Is that a hatch pattern created by someone else, that you yourself cannot create exactly in a blank file using on HATCH command by chance? "copy/paste" and "it won't let me create" seem to point to that.
Ask that DWG file creator that placed the hatch to share that hatch PAT file/code with you, it's required to do anything like you stated in AutoCAD.
You are welcome to share that elevation with that hatch here if you want someone over here to confirm it is not a stock hatch pattern but came from outside/another source too.
TIA
TIA
swallis3DMS4
in reply to: pendean
swallis3DMS4
Observer
Observer
So if I no longer had access to that previous drafter's files/codes, the hatch pattern is essentially burnt, and I'd have to try and replicate it from scratch?
Kent1Cooper
Kent1Cooper
Yes.  That kind of pattern you can easily create with RunningBondHPG.lsp, >here<.  The HPG stands for Hatch Pattern Generator.  Read the comments at the top of the file.
Kent Cooper, AIA
Kent Cooper, AIA
pendean
pendean
Community Legend
Community Legend
You could try a LISP like this to speed up the recreation of that hatch as another option
https://www.cadforum.cz/en/download.asp?fileID=1208#:~:text=Free%20applications%20and%20CAD%20utilit...
OR try the attached.
AutoCAD Inside the Factory
