Turn off noise when moving drawing using middle mouse button
Message 1 of 20
My computer keeps coming out low volume noise 'ziiii' only when I move my CAD drawing using middle mouse button. Does anyone know how to turn it off? The noise is very annoying when I am using AutoCAD in a silent place.
Replies (19)
Message 2 of 20
Tomislav.Golubovic
That must be a setting elsewhere, because AFAIK there is nothing in AutoCAD to do that.
Message 3 of 20
RobDraw
If it's a silent workplace, why are your speakers on?
There is no sound generated from AutoCAD when panning with MMB. Does it happen in other programs?
Rob
Message 4 of 20
ennujozlagam
go to your Windows Control Panes and sounds and turn it off. thanks
Message 5 of 20
pendean
Community Legend
Community Legend
Talk to your IT folks if you find this link here a challenge to follow https://www.computerhope.com/issues/ch001408.htm
Message 6 of 20
The noise still exist even if I turn off my speaker
Message 7 of 20
not working 😢
Message 8 of 20
RobDraw
Where is the sound coming from then? Computer or mouse?
Rob
Message 9 of 20
Computer, it is a laptop
Message 10 of 20
RobDraw
Do laptops have a system speaker in addition to the regular speakers like desktops do?
Have you tried a different mouse, yet?
Rob
Message 11 of 20
pendean
Community Legend
Community Legend
Ask your IT people for help, if you don't have one, take it to a computer store and use their HELP desk.
Message 12 of 20
fatima.f
Observer
Observer
Interestingly, I'm experiencing this too and will revisit this Topic if I get around to finding a solution that works for me.
It's not only when I use the middle mouse button, but also when using the actual pan command too.
Message 13 of 20
RobDraw
What is this mysterious sound? Can you record it?
Rob
Message 14 of 20
Zlatislav.atanasov
I suppose this is connected to the fans. When panning the Processor starts working harder, graphic card too, so they need more cooling...
Other than that, maybe the hard drive? Are you using a Hard drive or a SSD?
My personal blog - AutoCAD and AutoCAD Civil 3D hidden Secrets and great tips in one place -
https://skillamplifier.com/
Amplify your skills to a new level!
Message 15 of 20
joefranco6047
I think I may have found the problem.
I have the same issue, when moving my crosshair, but only in AutoCAD.
I have two independent external speakers (Roland  MA-12C) with their own power cable, plugged into a power bar, where my computer and other equipment is plugged into it too.
I turned off "Hardware acceleration" and the sound disappeared.
So, there seems to be an interference between the graphics card and the sound card.
At first I thought the problem originated from the power bar, So I connected the speaker on a wall outlet on a different circuit. Now I have continuous buzzing, without moving the mouse. I guess, my power bar filters out a lot of noise.
So in conclusion, it's the interference between the graphics card and the sound card.
I did some research and found out the the graphics card is creating a ground loop.
One other solution to remove the ground loop is to get a "Ebtech Hum Exterminator" from Amazone.
I use a "ground lift adaptor" and it works, they sell for a few dollars compared to the Amazone product at $119.00CAD
P.S. Hardware acceleration is back on 😉
I hope this solves your problem
Cheers
Joe
Message 16 of 20
i_floroiu
Community Visitor
Community Visitor
i dont have any external speakers, but the sounds its still on.
Message 17 of 20
cadffm
tried to unplug ALL unneeded things like usb hub and external drives and more?
with Hardware acceleration ON and OFF ?
Command: Graphicsconfig
Sebastian
Message 18 of 20
pendean
Community Legend
Community Legend
Take your PC to a repair shop and demonstrate it to them, they can help or diagnose/fix the issue for you.
Message 19 of 20
joefranco6047
For a test, try plugging your computer on a "ground lift adaptor" to see if it removes the buzzing. If it does, then something in your PC or power supply in your PC is creating a ground loop. Most probably it's your power supply.
Message 20 of 20
joshua_d_bearinger
Community Visitor
Community Visitor
Hi! For anyone still searching this: You are most likely experiencing GPU coil whine when utilizing the middle mouse button to move your CAD drawing. This can be triggered by certain events, which utilize certain voltages. This is pretty common in modern GPUs, and you can search how to fix it - but it will most likely be an issue you'll just learn to live with.
Hope that helps!
