has anyone ever seen this dialog, random block names no longer assigned
Message 1 of 10
when ever I use ctrl + shift + V to paste from the clipboard I get this dialog, have never seen this before and want to get rid of it. it wants to give blocks a name instead of assigning random names like usual
Replies (9)
Message 2 of 10
RobDraw
That's a new one by me, too.
Do you have any standalone attributes in what you are trying to paste?
Rob
Message 3 of 10
Thanks for responding it is in the acad.lsp file someone has redefined the copypaste command to display that dialog and not assign a random name.
Thanks again
I just found it
Message 4 of 10
I'm with @RobDraw - never seen this behavior either
Tested with several random objects, both with blocks and also random geometry, text, etc. (including/not including a standalone attribute) and I can't reproduce it....
AutoCAD (plain vanilla, no add-ins) 2020.1.2
My opinion is exactly the opposite of yours however, as there are times I would consider this useful. If you figure out how you got ACAD to behave this way, please post!
Message 5 of 10
the problem is someone added and redefined the command in autolisp below you will find the autolisp file that autoloads to do the task you can find the lines very near the top of the file.
I just found this. And yes some people find this very useful others not so much.
Good luck and thanks for responding.
Ken
Message 6 of 10
No attachment- I think you will have to either zip it or insert the plain text into a post. Sometimes active content filters get in the way of useful stuff
Thanks in advance!
Message 7 of 10
if you send me the your email, and if not here is the text to insert near the top of the file.
;; PasteBlockWithName.lsp
;; To require a User-supplied Name for each Block created with the PasteBlock command,
;; at insertion, avoiding the native command's meaningless names, e.g. "A$C578A4EC7".
;; UNDEFINES and MAKES A NEW DEFINITION OF the PasteBlock command.
;; Kent Cooper, last edited 24 June 2015
;; To preserve AutoCAD's PasteBlock command definition, remove the following lines:
(setq cmde (getvar 'cmdecho))
(setvar 'cmdecho 0)
(command "_.undefine" "PASTEBLOCK")
(setvar 'cmdecho cmde)
(setq cmde nil)
;; and Redefine PasteBlock if necessary, CHANGE the COMMAND NAME in the
;; next line of code to something appropriate [it will then NOT be invoked by
;; Ctrl+Shift+V], and adjust descriptive comments above and prompt at end.
(defun C:PASTEBLOCK (/ newname cmde); new definition
(while
(not
(and
(setq newname (lisped "Name for Block to be Inserted"))
; calls up Text Editor with content pre-selected for replacement
(setq newname (vl-string-trim " " newname)); remove any leading/trailing space(s)
(/= newname ""); didn't either clear out or enter only space(s)
(/= newname "Name for Block to be Inserted"); didn't just hit Enter
(not (tblsearch "block" newname)); name not already in use
); and
); not
(alert
(cond
((= newname "") "Empty string or only space(s) not allowed;\nyou must supply a Block name.")
((= newname "Name for Block to be Inserted") "You must supply a new Block name."); Enter only
(T "\nThat Block name is already in use.")
); cond
); alert
); while
(command "_.pasteblock")
(while (> (getvar 'cmdactive) 0) (command pause))
;; finish _.PASTEBLOCK including possible Scale/Rotate options, etc.
(setvar 'cmdecho 0)
(command "_.rename" "_block" (cdr (assoc 2 (entget (entlast)))) newname)
(princ)
); defun
my email is [email protected]
Message 8 of 10
ВeekeeCZ
It's build-in small STRING editor for LISP functions usage. Type this to your command-line to see...
(lisped "Name for block...")
It looks like you have some custom routine assigned to your shortcut.
Message 9 of 10
Got it, thanks again!
Message 10 of 10
cadffm
CTRL+SHIFT+V start the _pasteblock command, it's the standard shortcut function
Sebastian
