Demo Hatch
Demo Hatch
Demo Hatch
I work a lot with demo drawings for a buildings HVAC components (equipment, ductwork, piping, etc.) and the way I show demolition is by a hatch pattern covering whatever is removed.  Normally I outline the equipment, then use the HATCH command to fill in the outline.  I am curious if there is a way to just outline an object and it create a demo hatch over whatever was just outlined.  Almost like creating a linetype but the linetype is the hatch pattern of a certain width.
I'm not sure if this description will make sense, please ask if there is anything I need to clear up.
SCREENSHOTS IN ORDER
1. Existing
2. Outlined equipment/piping to be demo'ed
3. Hatch generated of outline
pendean
Community Legend
Community Legend
Nothing built in does that: if you want to customize, the LISP forum is over here for help with coding something a bit faster to implement https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
neaton
Until you find a coding solution, you might try the Draw option of the Hatch command; it is one of the command line options. You create your boundary and hatch at the same time instead of having to create an outline then hatch it.
Nancy
