Hardware acceleration
pisanom
Message 1 of 12
pisanom
Hi
I have been using AutoCAD 2022 for the past year without any issues with hardware acceleration. It was activated and working allowing me to view point clouds. My desktop is powered by a threadripper 3990x and 2 nvidia RTX A6000. This weekend AutoCAD stated there was an update so I updated AutoCAD. After that when I loaded in the point cloud file it said hardware acceleration is not available. I was not able to enable it in the graphics setting in AutoCAD.  I tried completely uninstalling AutoCAD as per the AutoCAD knowledge form and still AutoCAD shows as there being no graphics card connected to the machine. Any help would be greatly appreciated
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Update your video card driver help much?
Did you try removing the update to see if the problem is resolved yet? Do so now.
Post screenshots of your ABOUT and GRAPHICSCONFIG command pop-ups too please.
Message 3 of 12
pisanom
Hi Pendean,
thank you for your response. I tried removing the update and there was no fix. A driver update also did not resolve the matter. I have even tried installing Autocad 2023 and the same issue is happening. Attached please find the screenshots
Message 4 of 12
pendean
Community Legend
Community Legend
Thanks for the screenshots: "software mode" in the GRAPHICSCONFIG pop-up would mean your video card driver is not capable of running AutoCAD 2023.
Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT2023: reverting to DirectX11 may help and let you reset Graphicconfig command back to maximum performance.
If that fails, start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
Message 5 of 12
pisanom
Hi Pendean,
Is there any reason that autodesk would list the cards as being supported but then the software doesn't support them? Where would I set the GFXDX12 variable to 0? I appreciate all of your help!
Message 6 of 12
pendean
Community Legend
Community Legend
Yes, as I wrote "... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT2023..."
No one here is Autodesk: sorry.
Message 7 of 12
pisanom
So I tried that and still no luck. I was looking at this guide from auto desk
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Hardwa...
It seems that AutoCAD 2023 does not install a hardware database file like the guide says
  • Check that the hardware database file is present, located here:
    • C:\Users\Public\Documents\Autodesk\AutoCAD 20xx\Rxx.x\PTXML\CertificationDB.xml
It also does not have in the registry a firstrun entry as listed in the guide:
In the Registry Editor, browse to and select the following registry location:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:40x\3DGS Configuration
Is this something that other people have noticed?
Message 8 of 12
pendean
Community Legend
Community Legend
Not seeing any issues on any of our desktops and laptops we are testing now in the office with the 2023s, but we don't use your video card either
Did you reach out to Autodesk Support through your accounts page yet? That's your next step.
Message 9 of 12
pisanom
Hi Pendean,
Were you able to see if your AutoCAD installed files in that location and had the correct registry entries? Unfortunately it seems for students we don't have access to support.
Message 10 of 12
pendean
Community Legend
Community Legend
@pisanom that's unfortunate.
OOTB AutoCAD2023 installations for all of us, no one needed to jack with anything in the Windows Registry.
Message 11 of 12
pisanom
Just to make sure it wasn’t my graphics cards I tried with a Quadro RTX 8000 and a GeForce 2080ti and had no luck. Though on my laptop which has a quadro rtx 3000 mobile processor it works completely fine.
Message 12 of 12
jorge_lopez_adsk
Did you try clicking the Restore Defaults button in 3DCONFIG? Curious if that fixes the issue.
Jorge Lopez
Distinguished Engineer
