AutoCAD Forum
Hardware Acceleration turns itself off with current NVIDIA GE Force 730 driver
6 REPLIES 6
1565 Views, 6 Replies
Despite having an NVIDIA GE Force 730 card installed, with the most recent version of the driver, AutoCAD will not keep hardware acceleration enabled.  As the program opens it starts out enabled but quickly disables it and it states that a problem has been detected by the graphics tuner.  If turned back on and then I open an existing drawing it turns back off again.  I have the latest version of the driver installed, I uninstalled and reinstalled it altogether, checked all the recommended settings and still it's not solving the issue.  It's the only graphic driver installed on my PC.  I've also noticed that my only option in the Hardware Acceleration window under 2D Display settings is Classic Mode when until recently I had 3 options to choose from.  I'm hoping someone has a solution that works because I'm out of ideas.
I've attached the Tuner Logs for both states (Hardware Acceleration enabled and disabled) in case it helps.
6 REPLIES 6
S.Faris
The mentioned graphic card of your's is not in the list of Certified Graphics Hardware check from this link. So that is the reason why Hardware Acceleration is not working.
SALMANUL FARIS
in reply to: S.Faris
We have 2 others in my office with the identical setup to mine and theirs works perfectly fine with the GE Force 730.  Mine worked perfectly until last week so I'm not sure the driver is the issue despite it not being listed on the Certified List.
S.Faris
OK.But that doesn't mean it has to work on yours.
Let's do a quick check
Version of Autocad on all this 3 PC are same? Command _ABOUT
Version of Windows on all this 3 PC are same?   Windows key + R, type WINVER(enter)
Version of Nvidia Graphic Card on all this 3 PC are same? check in the Nvidia Control Centre
SALMANUL FARIS
pendean
What changed on your PC that did not on the other two? Find out, if they do the same they will be broken too just like your setup.
in reply to: pendean
We compared the details and we're all running the same version of the driver, same hardware and software versions, same Windows 10 updates, same DirectX version, same everything basically.  We may just pull the graphics card and try a different one to see if it's the card that went bad.
S.Faris
Refer to this before going that far to get it fixed : Hardware acceleration periodically turns off in AutoCAD
SALMANUL FARIS
AutoCAD Inside the Factory
