AutoCAD Forum
Guidance for proper project preparation with Sheet Set Manager
1 REPLY 1
mrcdaros
125 Views, 1 Reply
Hello
does exist a guide possible from Autodesk where it is explained the right way to prepare a project with Sheet Set Manager and Windows Esplore folder organisation which says where all the different type of files should be stored?
Thank u
1 REPLY 1
VincentSheehan
in reply to: mrcdaros
You can check the Autodesk University site for classes on Sheet Set Manager. As for proper folders and where files are stored, it's up to you and your company standards. I've worked at a few companies and they were all different.
Here is one for an example.
https://www.autodesk.com/autodesk-university/article/Managing-Your-Sheets-AutoCAD-Sheet-Set-Manager
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Forma Design Contest
AutoCAD Beta
