The grips on my xclips have gone missing. I've set xclipframe variable to 1, but that hasn't solved the issue.
Anybody have/solve this problem before?
Solved by coleHP6KN. Go to Solution.
In my Options menu I opened the Selection tab.
Under Grips, every checkbox option is checked.
Yet still only one grip appears when I select an xclip.
I want the 4 grips that used to be on the corners of the clip to appear.
Is there a reason they went away? Is there a way to restore them?
All layers are unlocked. After "regenall" still only one main grip appears. I've opened a different file and the selected xclips show a main grip plus the 4 on each corner. So it must be something specific to the file?
Yes, I did thaw/turn on /unlock all of the layers, all of them, then REGENALL and tried again. And I did zoom in/out significantly. The problem is not that NO grips appear, but that only ONE main grip appears. The other 4 grips a the corners of the xclip still do not appear.
I don't believe the file is corrupt. So I just did a save-as from a file that works properly and copied in my linework. My new xclips in this file are working fine. So I'm just going to delete the file where the xclip grips are not all showing. Problem not solved exactly as I'd hoped, but my work around will have to suffice.
Thank you!
This is so strange!! I have AutoCAD MEP on one machine and regular AutoCAD on another. The XCLIP grips show up on the MEP machine, but not on the CAD machine. All settings are identical. I do not get it.
I did a regenall and all my Xrefs disappeared. I repathed them and when they showed back up the grips were back.
Just had this issue. Frameselection got set to 0.
Fix it by setting to 1
Frameselection
Controls whether the hidden frame of an image, underlay, clipped xref, or wipeout can be selected.
Value Description
0 Hidden frames cannot be selected.
1 Hidden frames can be selected.
NOTE: The FRAME system variable controls whether frames of all types are displayed or hidden.
The PREVIEWFILTER system variable may prevent the frame from redisplaying during selection preview, but the frame can still be selected.
Enjoy!!
