Grid Lines are not showing, despite parameters being set correctly in AutoCAD
bdesign71
Message 1 of 20
bdesign71
Hello, My grid lines are not showing. In drafting settings the paremeters are set correctly in terms of x and y spacing and a heavy line every forth instance. F7 on and off does not do anything. In the settings if i change to dots they show up ???.
@bdesign71
Title Topic has been changed by @Tiana_Y for better findability. Original Post: Grid Lines.
Replies (19)
Message 2 of 20
imadHabash
Toggling OFF / ON hardware acceleration from GRAPHICSCONFIG command may make differences . if not fixed please try to check updates from your Autodesk Desktop App . What is your CAD version ?
can we see this action by a screenshot please ?
Imad Habash
Message 3 of 20
bdesign71
Hello, graphicsconfig did not work. If I  start a new drawing the grid lines will show up, however, in others existing files there must a setting or variable that has been triggered. I am new at this forum and dont know how to do a requested screen shot. Basically the system gridlines are not showing up. Thanks
Message 4 of 20
imadHabash
if F7 didn't help , please attache one of these existing files here for testing ?  scroll down to Attachments .
while posting press the camera icon up there in the same active edit box .
Imad Habash
Message 5 of 20
bdesign71
Hi, Attached is a drawing with the problem. Thanks for your help.
Message 6 of 20
imadHabash
type DSETTINGS and from Snap and Grid tab do as below image .
Imad Habash
Message 7 of 20
bdesign71
Hi, I followed your image and this triggers the dots to show up. If I do not toggle the dot paremeter the grid does not show up ???
Message 8 of 20
pendean
Community Legend
Community Legend
Explore checking and unchecking this box (see image below)to get the effect you desire, otherwise this might be a good time to start posting screenshots from your desktop showing what you want/do not want.
Message 9 of 20
bdesign71
OK, HOW DO I POST A SCREEN SHOT, I HAVE NEVER DONE IT, THANKS
Message 10 of 20
pendean
Community Legend
Community Legend
You use this tool to capture it then save it to an image https://support.microsoft.com/en-us/help/13776/windows-10-use-snipping-tool-to-capture-screenshots
Then come to the website and post it like you did your DWG file earlier.
Message 11 of 20
bdesign71
Hi, I have attempted to snip an image of my screen with no grid, I have tried all the dsettings. ?? Thanks
Message 12 of 20
pendean
Community Legend
Community Legend
Post a screenshot of your ABOUT command pop-up please.
no issues getting a grid (dots here) in your file at ll with these settings:
Message 13 of 20
imadHabash
After long tries and attempts , i think that you have a corrupted file ( i can only get dotted grids NOT lines ) !!! i suggest to copy and paste all of your contents to a new CAD dwg .
Imad Habash
Message 14 of 20
bdesign71
I like this idea, how do get all my dim styles, text styles, layer groups, views, etc to attach with the copy and paste, Thanks
Message 15 of 20
imadHabash
from the NEW cad drawing type INSERT then browse to get your old one .
Imad Habash
Message 16 of 20
bdesign71
Insert brings up the block insert, I bring in the old drawing and have to explode it. All of the above mentioned styles, groups, and views dont come with the drawing I inserted. Thanks
Message 17 of 20
imadHabash
while INSERT dialog is active notice the lower left Explode box .
all used styles will come with inserted contents .
you can get layout views by right click on your layout icon and select From template... and get your old layout tabs .
You have an excited CAD dwg file , I'm still looking in it . 🙂
Imad Habash
Message 18 of 20
GrantsPirate
Set SNAPANG to zero (0).  Notice that the information below says if SNAPANG is set to other than zero the grid lines will not display.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 19 of 20
imadHabash
Yes ... @GrantsPirate
Command: SNAPANG
Enter new value for SNAPANG <90>: 0
Imad Habash
Message 20 of 20
bdesign71
If views dont arrive with the insert I will have to redo. The dimstyle, textstyle and layer filters do not arrive either. Thanks
