Graphic Acceleration Problem
Message 1 of 8
I got a Dell Inspiron 7586 with a Nvidia GeForce MX150. My CAD apps fail all the time. Is not a version issue because I have tried AUTOCAD 2018 and 2020 as well. I also tried updates but nothing. I tried turning graphic acceleration on and off but still crashes all the time or works really laggy. When using AUTOCAD I even get blue screens with the next stop code: "VIDEO_DXGKRNL_FATAL_ERROR" If someone could help me I would really appreciate it.
Replies (7)
Message 2 of 8
Alfred.NESWADBA
Blue screen nowadays means hardware defect or driver defect.
If the system is new then take it back to the shop.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
did you look up this error message?
its not related to Autocad or Autodesk
Message 4 of 8
Well, it only happens when I use AUTOCAD  or Inventor.
Message 5 of 8
Alfred.NESWADBA
Well, it happens in 2 different products.
Which other software are you running on your system with such a high graphic usage?
- alfred -
Alfred NESWADBA
Message 6 of 8
those two only, and never at the same time.
Message 7 of 8
Alfred.NESWADBA
>> those two only
And that's the reason, these 2 are the only ones really stressing CPU + GPU + memory.
So the chance to get errors with these applications is higher than just running word or so.
- alfred -
Alfred NESWADBA
Message 8 of 8
pendean
Community Legend
Community Legend
Friend, unlike you other programs, AutoCAD is going to find weakenesses in your video card and system and trigger crashes. It is hat type of software, it uses everything fully 100% of the time. In fact it is one of the best software out there to test failing hardware, it makes them crash.
Your blue-screen crash is a system weakness/failure: you need to take your hardware in for repair or replacement before you lose it all when the failure spread to other software.
tick tock tick tock tick tock tick tock... time is running out.
